Thermoforming describes the process
of heating a thermoplastic sheet to its softening point,
stretching it over or into a single-sided mold, and
holding it in place while it cools and solidifies into
the desired shape. The thermoplastic sheet is clamped into
a holding device and heated by an oven using either convection
or radiant heat until it is softened. The sheet is then held
horizontally over a mold and pressed into or stretched over
the mold using vacuum pressure, air pressure, or mechanical
force. The softened sheet conforms to the shape of the mold
and is held in place until it cools. The excess material is
then trimmed away and the formed part is released. Excess
material can be reground, mixed with unused plastic, and
reformed into thermoplastic sheets.
Thermoforming is commonly used for food packaging, but has many
applications from plastic toys to aircraft windscreens to
cafeteria trays. Thin-gauge (less than 0.060 inches) sheets are
mostly used for rigid or disposable packaging, while thick-gauge
(greater than 0.120 inches) sheets are typically used for
cosmetic permanent surfaces on automobiles, shower enclosures,
and electronic equipment. A variety of thermoplastic materials
can be used in this process, including the following:
- Acrylic (PMMA)
- Acrylonitrile Butadiene Styrene (ABS)
- Cellulose Acetate
- Low Density Polyethylene (LDPE)
- High Density Polyethylene (HDPE)
- Polypropylene (PP)
- Polystyrene (PS)
- Polyvinyl Chloride (PVC)
As mentioned above, there are different methods of forcing the thermoplastic sheet to conform to the mold. These types of thermoforming include the following:
Vacuum forming - A vacuum is formed between the mold cavity and the thermoplastic sheet.
The vacuum pressure (typically 14 psi) forces the sheet to conform to the mold and form the part
shape.
Pressure forming - In addition to utilizing a vacuum underneath the sheet, air pressure
(typically 50 psi, but up to 100 psi) is applied on the back side of the sheet to help force it
onto the mold. This additional force allows the forming of thicker sheets and creating finer
details, textures, undercuts, and sharp corners.
Mechanical forming - The thermoplastic sheet is mechanically forced into or around the mold
by direct contact. Typically, a core plug will push the sheet into the mold cavity and force it
into the desired shape.
Return to top |
